Question about material conversion and octane proxies.
Posted: Fri Dec 06, 2024 4:30 pm
Hello there,
i recently got some foliage models to use for my archviz renders, in 3Dsmax format, set up with Vray materials. So i needed to convert the materials, which i did with the built-in max plugin convertor. I would then save these models as a new file, to still keep the vray-rigged version, in case i needed them in the future, for whatever reason. Here i found out interesting thing, these newly saved files with octane material are often quite larger than the original file. Like 50MB file growing to 180MB. Which is not great.
My question is, any idea, why is this happening? I presume its something concering the modeling app, but its not result of the material conversion, right? It makes no sense that octane materialed model would be 3x as big as one with v-ray. But what do i know...
The other question i have, does using octane-proxies save up vram, when compared to simply instancing the model as is? Or its only useful to improve viewport performance in modeling app, as the proxy has usually fewer polygons than the standard instance, but their vram imprint is the same?
Thanks in advance for your responses and help
