OctaneRender 2025 for Inventor [OBSOLETE]
Posted: Mon Oct 14, 2024 9:33 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Inventor - TEST and STABLE releases.
Inventor Version
The plugin requires Inventor 2025 or 2026, Windows 64bit.
IMPORTANT : After installation of the plugin, go to Tools->Add-Ins and on OctaneRender for Inventor UNTICK Block and TICK Loaded/Unloaded and Load Automatically.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Inventor version and build number
- OctaneRender for Inventor version (ie. 1.20.1.10)
For more information
- Read the on-line manual
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Current STABLE build (Octane 2025.3)
2025.3.0.35 (30-Sep-2025)
- Compiled with Octane 2025.3
- Added support for Inventor 2026
2025.2.0.35 (21-May-2025)
- Compiled with Octane 2025.2
- Added the "UV coordinate with transform" node
- "Ray Step Increase Factor" pin has been added to the Medium nodes
- Updates to the "Chaos texture" node
- 11 New blend modes for output AOV layers
- Changed the maximum and default values for all kernels for "Parallel samples" and "Max. tile samples" pins.
- Added the "Camera mask" render pass
- Added option to the "Metallic Reflection Mode" pin of the "Metallic Material" node
- Add the "Pre-multiplied Alpha" pin to the "Output Aov"->"Blend"->"Texture" node
- The "Realistic lens camera" has been added - however the Aperture cannot be set by the plugin, so the FOV does not match with Octane.
- Not Implemented: Decals
- Not implemented: Mesh Vertex Rest Positions
- Added new Render AOV -> Alpha node
- Added a new pin Denoise Quality to the Camera->Imager and Output AOV->Open Image Denoise nodes
Inventor Version
Network Rendering
Support Issues
- 32 or 64 bit
- Amount of RAM
Limitations
Download Links
- For users with a Studio subscription license Demo version
