Layering Materials Node
Posted: Sat Sep 21, 2024 9:25 am
by interelectronix
What is the node to use when layering materials on top of each other and the bumps should add up.
The picture attached shows a reference pcb
White screen print (with bump)
Shiny metallic soldering pads (with bump)
Small holes (opacity though through the PCB material)
PCB Material green (with bump)
Re: Layering Materials Node
Posted: Sat Sep 21, 2024 7:42 pm
by interelectronix
Thank you very much for the composite material tip.
I'm still struggling with the bump height control and blurring the bump maps. Not having a blur node and having to do the OSL texture workaround is quite annoying.
