OctaneRender 2023.1.3 for Houdini production (2023.1.3.1)
Posted: Tue Jun 11, 2024 12:26 am
This is a production release of the OctaneRenderâ„¢ 2023.1.3.1 for Houdiniâ„¢ plugin compiled with the Octane 2023.1.3 core. This 2023.1.3.1 release is available for the latest Houdini production builds on Windows x64, Linux, and macOS arm64.
Houdini production builds supported by this release: 19.0.720, 19.5.805, 20.0.506, 20.0.547, 20.0.590, 20.0.625, 20.0.653, 20.0.688, 20.0.724.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only compatibility Houdini 20 build is supported (gcc9.3).
It is visible in the latest Launcher, and you can also download it from:
https://www.sidefx.com/download/daily-b ... ction=true
or direct download link: houdini-20.0.724-linux_x86_64_gcc9.3.tar.gz
We are looking into supporting the gcc11.2 build.
New features
To learn more about the new features and improvements of OctaneRender 2023.1.3, please check out the 2023.1.3 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2023.1.3.1 Studio+ license
Windows Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.805 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.506 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.547 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.590 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.625 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.653 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.688 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.724 - https://render.otoy.com/customerdownloa ... _Win64.zip
Linux Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 19.5.805 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.506 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.547 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.590 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.625 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.653 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.688 - https://render.otoy.com/customerdownloa ... _Linux.zip
Linux Houdini 20.0.724 - https://render.otoy.com/customerdownloa ... _Linux.zip
Release 2023.1.3.1 macOS Prime license
MacOS Houdini 19.5.805 - https://render.otoy.com/downloads/53/5f ... _macos.zip
MacOS Houdini 20.0.506 - https://render.otoy.com/downloads/4c/d2 ... _macos.zip
MacOS Houdini 20.0.547 - https://render.otoy.com/downloads/fb/47 ... _macos.zip
MacOS Houdini 20.0.590 - https://render.otoy.com/downloads/48/0b ... _macos.zip
MacOS Houdini 20.0.625 - https://render.otoy.com/downloads/69/6c ... _macos.zip
MacOS Houdini 20.0.653 - https://render.otoy.com/downloads/e6/f3 ... _macos.zip
MacOS Houdini 20.0.688 - https://render.otoy.com/downloads/d4/ce ... _macos.zip
MacOS Houdini 20.0.724 - https://render.otoy.com/downloads/63/36 ... _macos.zip
Release 2023.1.3.1 Demo version
Windows Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.5.805 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.506 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.547 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.590 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.625 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.653 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.688 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.724 - https://render.otoy.com/plugindownloads ... _Win64.zip
Release Notes
RELEASE 2023.1.3.1
* PLUGIN FEATURES AND FIXES:
- Added new orbx exporting option "Export .orbx File (Alembic)" from IPR which exports ALEMBIC node. The original option is renamed to "Export .orbx File (Geometry)"
- Fixed problem that Animated Light Intensity not update when time changes
- Truncate node names exported in orbx file to make the graph tidier
- Collapse nodes except Geometry in exported orbx file to make the graph tidier
- Fixed Photon Kernel's Exploration strength parameter
- Fixed IPR window stops staying on top after close IPR docked pane
- Fixed CustomAOV channel colour for Packed & Instanced obj
- Build Linux with OctaneSDK Studio+ gcc9 build (There is no gcc9 OctaneSDK demo build)
- New Universal light (Document of the new Universal light)
- Removed octane_ipr shelf
- Updated octane shelf
Common Issues and Solutions
- If the plugin doesn't work at all, set
- If you're missing
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
Linux Note
New features
Known bugs
Downloads
Release Notes
RELEASE 2023.1.3.1
HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.- If you're missing
libglut.so.3, install the freeglut package.- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
