OctaneRender 2023.1.3.0|OctaneSolaris - RC10[OBSOLETE]
adrianr
We're seeing some discrepancies in animation for shots rendered locally vs exported to orbx (Out of Solaris) and rendered on RNDR. In this case we have a rotating object, and the rotation doesn't quite line up (it's not a frame offset issue). Can you reproduce this your side?
Windows 11 | 14900k | 2 x 4090 | 96gb DDR5.
BK
adrianr wrote:We're seeing some discrepancies in animation for shots rendered locally vs exported to orbx (Out of Solaris) and rendered on RNDR. In this case we have a rotating object, and the rotation doesn't quite line up (it's not a frame offset issue). Can you reproduce this your side?
Hi Adrian, thank you for the post.
Would you please let us know if you are using the default Houdini scene scale Unit (meter) or modified as cms?
cheers
Kind Regards
bk3d
galleon27
OK so its been a month since 2023.1.3.1 main plugin has been released. When do you guys plan to release the Solaris plugin?
Also perspective correction is missing from universal camera.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
BK
galleon27 wrote:OK so its been a month since 2023.1.3.1 main plugin has been released. When do you guys plan to release the Solaris plugin?
Hi galleon27,
Thank you so much for the reminder.
We will do a release sometime this week if everything goes well..
Oh thanks for reporting the missing Perspective correction.. We have created an internal ticket.
Hope this option can be included in the new release.
Cheers
Kind Regards
bk3d
seriawp
Did you know that Light Pass Mask does not work with Directional Light?
But it works correctly with regular Area Light.
Here I created a post where I described this error
viewtopic.php?f=140&t=83510&p=434398#p434398
BK
seriawp wrote:Did you know that Light Pass Mask does not work with Directional Light?
Thanks, seriawp, for the reminder.
We can replicate this issue.
We hope to get it fixed asap!!
cheers
Kind Regards
bk3d
