C4D How to manipulate nodes in the Node Editor using Python?
Posted: Mon Mar 25, 2024 6:53 pm
I'm trying to automate something that I do manually all the time and it takes a long time. I have this Octane material that has these nodes that I want to edit. Basically set each of these shaders' files. So how do I get a references to these 52 nodes in the image? And to go a step further, is there a way to create them in any Octane material (and then get their references)?
I also have this simple script that opens the Octane Node Editor of the selected object. Not sure if this would be needed.
def main():
materials=doc.GetMaterials()
obj =doc.GetActiveObject()
if not obj:
c4d.gui.MessageDialog("Please select an object or a material tag.")
return
objMaterial= obj.GetTag(c4d.Ttexture)
if objMaterial == None:
c4d.gui.MessageDialog("Selected object has not a material tag.")
c4d.CallButton(objMaterial.GetMaterial(), c4d.OCT_MATERIAL_NODE_EDITOR)
c4d.EventAdd()
if __name__=='__main__':
main()
