About UV projection
Posted: Mon Mar 18, 2024 4:37 am
by M130
Is it possible to set the projection type of a texture to UV by a node even if the projection type of Cinema4D's material tag is set to Box?
On the other hand, I know that even if the material tag's projection type is set to UV, it is possible to project as a Box type using Trip lanar.
I asked this question because I needed it to achieve a slightly special texturing.
Re: About UV projection
Posted: Mon Mar 18, 2024 6:07 pm
by frankmci
Yes, the Octane Projection node in a material will override the setting in the C4D Material Tag.
Posted: Tue Mar 19, 2024 2:03 am
by M130
I would like to know the settings to override.
Posted: Tue Mar 19, 2024 1:18 pm
by SSmolak
Set texture projection in node to box. Also you can override any polygon of the object by custom, edited UV using standard C4D method : https://youtu.be/gMAuS6hvhYs?list=PL9lZ ... MWbM&t=143
Posted: Wed Mar 20, 2024 7:04 am
by M130
Thank you, everyone.
However, the method you taught me is different from what I was aiming for.
I also referred to the video that SSmolak taught me, but I realized that perhaps I needed a different approach to achieve what I was aiming for.
