sss map
Posted: Wed Jan 10, 2024 2:19 pm
by KotovMax
Hello, can anybody help? where to add sss map? every setup that i tryed didnt worked...
I have just 1 mesh and half has sss and other half doesnt. I know i can split this mesh into 2 and do them separetley but it must be the way to just add sss map somewhere there
please help, :? :( :roll:
thank you!
Re: sss map
Posted: Wed Jan 10, 2024 3:32 pm
by J.C
There are no input for sss map in medium nodes. You can use the map as mask factor between sss and non sss material for example..... or use it as a mask for mix texture for radius input in Random Walk node.
Re: sss map
Posted: Wed Jan 10, 2024 4:15 pm
by KotovMax
J.C wrote:There are no input for sss map in medium nodes. You can use the map as mask factor between sss and non sss material for example..... or use it as a mask for mix texture for radius input in Random Walk node.
i tryed, it didnt work :|
is there any way you can please send example in your screen picture how to connect it :cry: thank you!
Re: sss map
Posted: Sun Jan 14, 2024 2:58 pm
by kabakZ
just put your bw sss mask into the transmission socket... that's all
Re: sss map
Posted: Mon Feb 26, 2024 3:35 am
by KotovMax
kabakZ wrote:just put your bw sss mask into the transmission socket... that's all
i try everything and didnt found in transmission menu, where to add sss map =(
is it even possible to add sss map?
