Soft2Octane 2.52b [Obsolete]
Posted: Thu Sep 08, 2011 9:45 am
by face
A little fixdate ;)
Fixed in this version:
  • Textures should now be exported correct.
  • "Export Camera Only" will work again and use the "project.obj". But an ocs file must exists.
    On a new project, you must also first use the "Render Frame" button to export the mesh, set up and save the scene in Octane to create an ocs-file.
Enjoy!
face
Re: Soft2Octane 2.52b [CURRENT]
Posted: Mon Sep 12, 2011 4:02 am
by DanielKim3d
hi Face
I am new user of Octane, and using this Soft2Octane 2.52b now
What I have seen on another website is there is a button 'refresh' under misc tab, but I can't see it now. I have Misc tab, but there are only 'area light' 'logging' 'strands' 'compatibility' 'GPU devices' and 'plugin'. Please let me know what I should do in order to use refresh button
I am using SI 2012 sp1 now.
Daniel
Posted: Mon Sep 12, 2011 7:29 am
by face
DanielKim3d wrote:hi Face
Daniel
That was only a tech preview. To realize it, i would have to do for every new Octane version a new plugin per 32/64bit.
I think that´s to much work, because i must find the right code in the Octane executable which will be shown as assembler and jumps manifold forth and back.
But maybe it is possible if the Octane SDK is available.
Hope you can understand it...
face
Posted: Mon Sep 12, 2011 1:34 pm
by PeterCGS
Got a problem with Softimage stopping while rendering animation. It hangs in the beginning of a random frames, and nothing happens. If I press cancel on the export frame window, and press render animation again in the Soft2Octane window, nothing happens. And restarting Softimage doesn help, only if I restart the computer the render animation works again. But then hangs after a while.
/Regards Peter K
Posted: Mon Sep 12, 2011 4:10 pm
by face
PeterCGS wrote:Got a problem with Softimage stopping while rendering animation. It hangs in the beginning of a random frames, and nothing happens. If I press cancel on the export frame window, and press render animation again in the Soft2Octane window, nothing happens. And restarting Softimage doesn help, only if I restart the computer the render animation works again. But then hangs after a while.
/Regards Peter K
Take a look in the task manager under the processes tab, i think there is a running Octane task.
Octane seems sometimes not close correct after save a frame...
face
Posted: Mon Sep 12, 2011 5:47 pm
by PeterCGS
Aah.. Ok.. Will check!
