Post porcessing issue
Posted: Wed Feb 08, 2023 5:10 pm
by 62STARTREK
Hi all. As you can see in the pics below I have an issue with a rendering. I've activated the Post Processing settings (bloom effect) and in the Live Viewer it works, but in the final render (C4D system, not AOVs) it doesn't work. What am I doing wrong? Thanks
Re: Post porcessing issue
Posted: Wed Feb 08, 2023 7:03 pm
by aoktar
What's render resolutions? Post effects are pixel size based. Not rational to dimensions as you can notify
Posted: Wed Feb 08, 2023 7:36 pm
by 62STARTREK
Thanks for the reply, the render settings are 1280x800, 72 DPI.
Posted: Thu Feb 09, 2023 7:37 am
by bepeg4d
Please enable the Lock icon in Live View, to have the same resolution as Picture Viewer.
Please also check to have enabled the Use denoised beauty pass option in Render Settings/OctaneRender/Main tab, thanks.
ciao,
Beppe
Posted: Thu Feb 09, 2023 4:59 pm
by 62STARTREK
Ciao Beppe, "Use denoised beauty pass" is checked but now there is another issue. If I lock the Live Viewer I have a crash. If I uncheck it the render starts but with same previous issue. Here's the log report
Posted: Fri Feb 10, 2023 7:19 am
by bepeg4d
please upgrade Win 10 to 2004 or greater, then try again and report back, thanks.
ciao,
Beppe
Posted: Fri Feb 10, 2023 2:30 pm
by 62STARTREK
Hi, sorry but I don't undestand what 2004 means. The O.S. is automatically upgraded
Posted: Fri Feb 10, 2023 6:00 pm
by jayroth2020
Beppe is referring to Windows build 2004 or greater.
