Save Custom AOVs from lua
Posted: Fri Feb 03, 2023 10:18 am
by manusd
Hi, I'm trying to save Custom AOVs from lua scripting but when trying I get always the same error "not all the passes for tonemaping are enabled". I create an AOV node, connect it to the render target, enable it and save it with the correct render id pass. I'd appreciate it if someone can tell what I'm doing wrong. The code:
        --Create AOV node
        renderTarget = octane.render.getRenderTargetNode()
        AOV = octane.node.create
        type         = octane.NT_AOV_CUSTOM,
        name         = "AOV_Custom",
        renderTarget:connectTo(octane.P_RENDER_PASSES, AOV)
        --Enable  AOV and save it
        AOV:setPinValue(octane.P_SUB_TYPE, 0)
        AOV:setPinValue(octane.P_ENABLED, true)
        octane.render.saveRenderPass3(501, string.format("%s/%s_%s_mask_%04d.exr", basepath, basename, maskName[idx], imagenumber), img_type, propsRenderColorSpaceInfo, 0, exr_comp)
        end
thanks
Re: Save Custom AOVs from lua
Posted: Fri Feb 03, 2023 11:47 am
by manusd
The issue was provoked for not enabling the AOV mask before starting the render, it's already solved.
