Export to standalone, can't find scene render node
Posted: Tue Jan 17, 2023 11:53 am
by HHbomb
Sometimes when I export a scene to standalone I can't find scene render node.
No problem to batch render, but I can't make any change for the render as I can't select the node...
Any clue ?
Re: Export to standalone, can't find scene render node
Posted: Wed Jan 18, 2023 12:31 pm
by HHbomb
@elsksa
Hi, I'm not very familiar with Octane standalone. I'm very frighten with its UI because I use to clic, scroll,... a lot as in Max and in Octane UI I make a ot of unwanted things :-)
In scene outliner I can't find target render node in some export.
If I clic on Target render node in node inspector, I should have the node selected ?
Posted: Thu Jan 19, 2023 9:44 am
by paride4331
Posted: Fri Jan 20, 2023 8:32 am
by HHbomb
@elsksa
Thanks but target node isn't present in this window.
As soon I finish my project I'll insvestigate in this problem ... :-)
Posted: Fri Feb 03, 2023 1:12 pm
by HHbomb
Hi, as I don't like to say something wrong, I checked my octane files and found every time a scene render target... :roll:
I suspect my problem to be from using different versions of the software or before 11/28 update ( ??? ) and for my render job I needed to have both computers to be on same version.
Now it seems to be ok, except that buttons in the Node inspector like "Selects the render target node and shows it in the node inspector" works only if the Scene render target had been selected in scene outliner.
All is fine, I'm happy ! :-)
