Octane 2022.1 for Unreal Engine - 0.62 Lightmass
Posted: Fri Jan 06, 2023 3:11 pm
by ChrisHekman
Octane for Unreal Engine
Changes:
  • OctaneLightmass: First version of the octane lightmapper for unreal (experimental)
  • ORBX Import: ORBX files that use alembic as geometry format can now be dissasembled into multiple static meshes that are placed in the level.
  • ORBX Import: Alembic conversion to geometry cache assets has been greatly improved all round
  • ORBX Import: Import Settings are now saved for next import
  • ORBX Proxy: ORBX proxies how have the option to use external orbx files via absolute paths.
    These ORBX files will not be copied over into the ORBX uasset and will remain at their location.
  • Materials: Added support for certain HLSL functions in custom code nodes (Mainly fixes a couple Metahuman materials, maybe some others)
Fixes:
  • Landscape: Fixed crash in 5.1 that occurs when opening a level that contains a landscape when octane is already active
  • ORBX Import: Fixed various mesh slot connection issues with materials
  • Materials: fixed refraction issue
UE 5.0
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
UE 5.1
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_1.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_1.exe
Re: Octane 2022.1 for Unreal Engine - 0.62 Lightmass
Posted: Thu Jan 12, 2023 2:38 am
by EvolverInteractive
Thanks Chris, trying the Lightmass getting a bit of crashing on lightmaps get applied.
Posted: Thu Jan 12, 2023 2:47 pm
by theghalwash_forum
i get this message whenever i install a new plugin release
Posted: Thu Jan 12, 2023 9:57 pm
by ChrisHekman
theghalwash_forum wrote:i get this message whenever i install a new plugin release
It seems you are logged into your octane account on a different pc?
You can log in to otoy.com and unlock your subscription/license in the subscription or the licensing panel.
Posted: Fri Jan 13, 2023 1:25 pm
i am using the same pc. but about 4 months ago i did a resr and changed my pc name. since then i keep getting this message. i unlock it from my license setting it works fine until i install a new release it shows again until i reset it. now i have only one reset left in the tank. so how sustainably can i solve this issue. thanks in advance
Posted: Wed Feb 08, 2023 5:42 am
by azen
This issue was likely caused by outdated/voided license activation data. Typically, License Activation data on your active machine can be affected by the following:
  • A system crash that occurs while Licenses are still activated
  • Shutting down a machine suddenly (before the software can release the Licenses properly), and making significant changes to your hardware
  • Changes to the operating system, or network configuration, on a machine with activated licenses
  • Changing your internet connection (i.e. logging out of one mobile network to log into a private Wi-Fi) without releasing your license first
Typically, you can deactivate licenses by simply closing your software before shutting down/resetting your machine. So long as the licenses are deactivated on the machine prior to any significant updates or changes, this issue should be easily avoidable in the future.
