Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
SSmolak
Instance Projection doesn't work as expected in C4D like this : https://youtu.be/YqrgI1bAggs?t=18
Scene included.
I recreated step by step scene from Octane Standalone and it doesn't work in C4D too : viewtopic.php?f=9&t=79836&start=10#p413165
inst_proj.zip
(105.4 KiB) Downloaded 226 times
SSmolak
Sphere display type in Scatter create spheres using Axis Y always at the centre even if object has axis Y in other place. Other preview modes works fine.
Scatter_sphere_mode_axis_issue.zip
(366.72 KiB) Downloaded 198 times
marcus1070
Another spline without hair option under cloner, but this time, is the mospline object.
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
thanulee
marcus1070 wrote:Another spline without hair option under cloner, but this time, is the mospline object.
And segment (capsule) also not recognised
FxDesign
There is a bug with the aspect ratio.
When I work in 1080x1080px, the live viewer is cropped
FxDesign wrote:There is a bug with the aspect ratio.
What happens when you set ZOOM to 1.0?
alexlomarco
Maybe because you zoomed out with the mouse wheel ?
Gregor.Zimmermann
@FxDesign
You can fix that by clicking the lock icon in the LiveViewer window.
FxDesign
Yes it works, it's definitely not a bug, thank you guys :)
thanulee
can we fix denoised pass when saving from LV to be in ACES as well? thanks
