hard edges with bump
AdrienG
Hi everybody,
Simple noobie question i guess :
Once i plug a proc noise in bump it bring me hard edge.
How to fix that ? cheers
BK
AdrienG wrote:Hi everybody,
Hi AdrienG,
Thank you so much for sharing the rendered images.
Would you please try using the **OpenSubD level** from the Attribute Editor>Octane rollout and see if it goes away?
cheers
Kind Regards
bk3d
AdrienG
Hi thanks for the feedback. i tried that but it simply subdivide the geo which i try to avoid. I ve got a mesh to render which is not smooth friendly because imported from a step file..
It looks like it does the same with normals maps..
It feels very weird, i ve had used redshift (and other renderers before that) and i didnt have this kind of situation. Is that because of the light behaviour and the lowpoly angle between faces?
BK
AdrienG wrote:Hi thanks for the feedback. i tried that but it simply subdivide the geo which i try to avoid. I ve got a mesh to render which is not smooth friendly because imported from a step file..
Hi AdrienG,
Thanks so much for clarifying.
The issue might be related to mesh edge. Would you please try "Soften Edge" operation from Mesh display menu and see if it resolve?
If not, then please share the scene for us to investigate!
cheers
Kind Regards
bk3d
AdrienG
i need help for that because i cant figure out whats the issue, to me it looks like a plug in dev problem, hopefully you ll tell me i m wrong.
Whatever i do with my normals (soften/lock unlock/vertex/faces...) the bump (a basic oct noise) is bringing that hard edge look.
I share another render comparaison.
plus, a very basic scene with a torus if you want to try.
Cheers
AdrienG
edit : cant send *.ma here but the scene is the most simple, torus with noise bump : impossible to get rid of thats edges, to smoooth them out....
BK
AdrienG wrote:edit : cant send *.ma here but the scene is the most simple, torus with noise bump : impossible to get rid of thats edges, to smoooth them out....
Hi Adrien,
Please try elsksa's suggestion also have you tried attaching the OctaneRound Edge node?
If it still does not work then please zip the .ma and upload it?
cheers
Kind Regards
bk3d
astor
Maybe your model size is too big
try it. scale 1=>0.1
AdrienG
Scene scale didnt bring much and to my mind thats a dangerous setting to play with.
Nevertheless, i found this post which talks about the same issue, lowpoly/blocky self shadows :
viewtopic.php?f=32&t=69511
adding a slight displacement works great (dont forget to use the texture baking node if you use proc noise)
checking on the material shadow path term. seems to work too
Return to “Autodesk Maya”
