Unable to import orbx scene to unreal if polygon selection t
Posted: Thu Oct 06, 2022 11:59 am
If the scene uses a polygon selection tag (cinema 4d) and I save the scene as orbx, then when it is imported into unreal, it crahed.
Community Forums for OTOY Customers
https://render.otoy.com/forum/
Interesting, could you share your orbx with me? It would me save time as I am not very familiar with the c4d plugin.banandai wrote:If the scene uses a polygon selection tag (cinema 4d) and I save the scene as orbx, then when it is imported into unreal, it crahed.
Im using Octane plugin and Orbx format to import. With c4d plugin no problemInteresting, could you share your orbx with me? It would me save time as I am not very familiar with the c4d plugin.
I think I fixed the crash. It will be part of the next build.banandai wrote:Im using Octane plugin and Orbx format to import. With c4d plugin no problemInteresting, could you share your orbx with me? It would me save time as I am not very familiar with the c4d plugin.
I think it's related to the scene, because if I remove all geometry and create a default cube, the unreal one fails. But I can't figure out what exactly is wrong in the scene and why if I remove all polygon selection tags everything works.
I uploaded 2 versions in Orbx format and one in cinema format, if you need something else, write to me.
https://drive.google.com/drive/folders/ ... sp=sharing
and also, if I export as animated package, then everything also works. An error occurs when importing with Polygon Selection tags only when static package exporting
