OctaneRender for DAZ Studio 2021.1.5 - 70 [OBSOLETE]
Posted: Fri Jul 22, 2022 12:08 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for DAZ Studio - TEST (ie. pre-release) and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you are running the latest version of the OctaneRender for DAZStudio plugin.
3) If you experience a DAZStudio crash - deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb may resolve the issue.
This also resolves the "COULD NOT INITIALISE IN-MEMORY DB!" error on startup and a number of other issues.
4) If the Save button is disabled when using the Final button - disable the Final button and in Render settings select the SuperScope (2:1) Size / aspect ratio and drag the Viewport height or width until you reach required resolution.
5) If rendering an animation fails after 11 frames - make sure the DAZStudio viewport is visible when you render the animation.
6) If Octane materials are not loading when you load a previously saved scene - tick Preferences->Load OctaneRender materials from .duf user presets. If ticking this option does not stick between DAZStudio restarts, delete OctaneRender_settings.oczdb as per NOTE 3 above.
7) If you get a "Could not save a frame for X times!" - please refer to the thread at
for potential solutions.
8) If you get a "Bogus Scene Path" error - this is due to having an apostrophe in the filepath of a texturemap (so store your textures in foldernames which do not have apostrophes).
9) Octane panel title bar is off the screen and cannot be closed - click anywhere on the Octane panel and then press Alt-F4.
10) Rendering animation results in the scene emitter intensities changing - this is because rendering animations is done in "Final" mode, where meshes are merged. To resolve this, UNTICK the Preferences->Use Combined Mesh, or ENABLE the Surface Brightness pin on each of the emission materials in the scene.
11) Denoiser is not working - make sure you have a graphics card selected for Denoising in the System tab->Open Device Settings window, and that you are using the Path Tracing kernel.
12) Render artifacts near eyebrows - this is due to the eyebrow geometry going inside the head mesh surface. So morph, move or scale the eyebrows so they do not intersect with the head mesh.
13) Octane panes do not appear on the screen (ie. they open off the screen) - Main Menu Bar->Window->Workspace->Select Layout->Accept (you might choose a different layout to the current layout to make this work).
KNOWN ISSUES AWAITING RESOLUTION
1) Custom LUT, Panoramic camera and OSL nodes are not currently supported.
2) Templating is not currently working for specular and roughness maps from Iray materials. - FIXED (please report any issues)
3) UDIM Tiles are not currently supported.
4) Some of the newer OctaneRender material and texture types are not supported. - Most are now supported
DAZ Studio Version
DAZ Studio 4.8 or later on Windows 8, 10 or 11 64bit
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped.
Also, make sure you use an Nvidia Studio driver of version 451.xx or higher.
Network Rendering
For Network Rendering, you must use the OctaneRender Enterprise Node release from the Octane Standalone forums/download page which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Enterprise 2021.1.5 Render Node builds.
Support Issues
- Operating System (ie. Win 8, 10, 11)
- Amount of RAM
- Nvidia driver version
- DAZ Studio version
- OctaneRender for DAZ Studio version (e.g. 2021.1.5_70)
- The most important part of resolving a problem is being able to reproduce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Change logs since 2021.1.5 - 69 [Test]
Please feel free to report any issues you encounter.
Happy rendering
Your OTOY team
DAZ Studio Version
Network Rendering
Support Issues
- Amount of RAM
- Add support for Visible Environment
- Please see the OctaneRender Standalone documentation for what this does: https://docs.otoy.com/StandaloneH_STA/S ... onment.htm
- To change the Visible Environment, change the new drop down in the Environment tab from "Normal" to "Visible"
- Allow "Smart unfold" (again) for material nodes in the nodegraph editor
- The sharing of identical nodes during Smart unfold has been disabled - please let me know if this was useful to you
- Fix corruption of connections when smart unfolding produces connections that already exist
- Add some missing node types for use in the nodegraph editor
- Added selectable materials:
- Null Material
- Clipping Material
- Added selectable textures:
- Iridescent
- Smooth Voronoi Contours
- Tile Patterns
- Procedural Effects
- Chainmail
- Moire Mosaic
- Color Squares
- Stripes
- Flakes
- Fractal
- Hagelslag
- Glowing Circle
- Cell Noise
- Gradient Generator
- Floats to Color
- Float3 to Color
- Float to Greyscale
- Curvature Texture
- Ray Direction
- Normal
- Position
- Relative Distance
- UV Coordinate
- Z Depth
- Surface Tangent dPdu
- Surface Tangent dPdv
- Sample Position
- Chaos Texture
- Random Map
- Range
- Binary Math Operation
- Unary Math Operation
- Spotlight Distribution
- Channel Picker
- Channel Merger
- Ray Switch
- Channel Inverter
- Channel Mapper
- Capture to Custom AOV
- The organization of node types in the nodeograph editor has been aligned with OctaneRender Standalone
- Fixed some issues with Daz cameras with "Use Local Dimensions" enabled
- Fixed locating images containing XML-special characters in the Daz content library
- For users with an Enterprise subscription license For users with a Studio subscription license For users with a Prime/Free Tier license
Happy rendering
Your OTOY team
