render like vray wirecolor or object ID chanel
Posted: Mon Aug 29, 2011 2:47 pm
by lzanlorenzi
Hi friends.
a simple question: it´s possible to octane render a chanel like objet ID color or like vray wirecolor?, it´s too much easy to select objects in photoshop to pos production or color correction.
thanks for your time.
Re: render like vray wirecolor or object ID chanel
Posted: Tue Aug 30, 2011 5:16 am
by tehfailsafe
If you have vray you can always knock out another render and comp it. I am doing that now, actually. Vray is taking over 8 hours to render an animation, and octane is taking about 45 mins to do better quality... But the client wants render passes ( not reflection or diffuse type passes but object mattes, zdepth, velocity, etc ).
So I just setup a render sequence in octane, then matched it in vray with super low DMC settings like .05 noise threshold ( the passes I want don't rely on noise settings ).
Tested the comps in AfterEffects and they line up perfectly. However, I will say I'm not sure how octane lines up HDRIs, I'm using the same one in both and I get very different lighting angles. Will be testing that after I find some free time.
Posted: Fri Sep 02, 2011 1:03 pm
by lzanlorenzi
ok.. i have same idea . but will be much better if we do that in octane.. like arion render or fryrender.
but thanks for reply... hugs and good weekend for u
