DOCUMENTATION ADDENDUM: Background Plate
Posted: Tue Mar 22, 2022 11:58 pm
by face_off
Option 1 - Octane Visible Environment
Where a Modo "Environment Color" has Projection Type = Front Projection, add an Octane Visible Environment (https://docs.otoy.com/ModoH/ModoPluginM ... onment.htm) to the Environments in the Shader Tree, and add the above image to that mask.
Click the Visible Environment button on the Octane toolbar and enable Use RGB Color. Now drag the Visible Environment RGB Color onto the schematic and set the nodes up as follows (note the Octane Transform X Scale is set to -100%).
The Octane Viewport should now match the Modo render.
Option 2 - Compositor
Drag the Kernel->AOV Output Group property onto a workspace, and setup the compositor as follows. Turn on Kernel->Alpha Channel.
A sample .lxo using this approach is below.
aov.zip
(14.88 KiB) Downloaded 2015 times
Re: DOCUMENTATION ADDENDUM: Background Plate
Posted: Tue Aug 02, 2022 9:58 pm
by Davve
Hi paul!
Is this the way to render a backdrop image ? I've been having trouble with that previously.
When I tries this method the only result I get is the image on a sphere and not a plane projected from the camera...
D
Posted: Wed Aug 03, 2022 11:21 pm
by face_off
Hi
You can assign a background image for visual purposes -> https://docs.otoy.com/ModoH/ModoPluginM ... Kernel.htm. You can also use the Front Projection (https://docs.otoy.com/ModoH/ModoPluginM ... projection).
Posted: Wed Jan 11, 2023 2:31 am
by face_off
I have updated the post at the top of this thread to include "Option 2 - Compositor".
Posted: Thu Jan 12, 2023 8:30 pm
by jwfvr
thank you!
