C4D crashes and won't open with Rosetta enabled
Posted: Mon Feb 21, 2022 10:20 pm
by cbaadvertising
I've been trying for 2 days to get octane to work with C4D.
I've tried putting Octanex in plugins folder, in preferences plugins folder, Installing C4D with the maxon app, with the offline installer.
Without enabling Rosetta my octane doesn't show up anywhere.
When I enable Rosetta C4D doesn't open, just crashes "Cinema 4D: Application Error"
Anybody else had this issue and resolved it? Any help is appreciated. Thanks!
About This Mac:
System Version: macOS 12.2.1 (21D62)
Model Name: MacBook Pro
Model Identifier: MacBookPro18,2
Chip: Apple M1 Max
Unknown
Unknown
Total Number of Cores: 10 (8 performance and 2 efficiency)
Memory: 32 GB
Graphics/Displays:
Apple M1 Max:
Chipset Model: Apple M1 Max
Type: GPU
Bus: Built-In
Total Number of Cores: 24
Vendor: Apple (0x106b)
Metal Family: Supported, Metal GPUFamily Apple 7
Displays:
Color LCD:
Display Type: Built-in Liquid Retina XDR Display
Resolution: 3456 x 2234 Retina
Main Display: Yes
Mirror: Off
Online: Yes
Automatically Adjust Brightness: No
Connection Type: Internal
Thunderbolt:
Speed: Up to 40 Gb/s x1
Network:
Type: Ethernet
Media Subtype: none
Type: Ethernet
Media Subtype: none
Type: Ethernet
Media Subtype: none
Type: AirPort
DHCP Message Type: 0x05
Media Subtype: Auto Select
Type: Ethernet
IPv4 Addresses: 172.20.20.20
OctaneRender¨ daemon installed:
not active at startup
daemon is not running
OctaneRender¨ applications installed:
Octane X Enterprise PR13
Maxon Cinema 4D and c4doctaneX versions installed:
Maxon Cinema 4D R25:
OK - current 25117- minimum 25001
OK - folder name = plugins in lowercase
c4doctaneX installed in:
Applications/Maxon Cinema 4D R25/plugins/c4doctane
/Users/ggordillo/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/c4doctane
OK - c4doctaneX is correctly installed in Preferences/plugins folder
OK - c4doctane is Not in plugins.json
Octane SketchUp plugin installed:
Not-Found
Re: C4D crashes and won't open with Rosetta enabled
Posted: Tue Feb 22, 2022 8:01 am
by bepeg4d
please remove the second c4doctane folder in /Users/ggordillo/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/, one c4doctane folder is more than enough.
Please note that, if Open with Rosetta option is enabled in C4D, you cannot work with other native plugins, like X-Particles or RedSHift, and you need to install only non-native plugins, along with C4D-OctaneX-PR13.
A native M1 c4doctane version is expected with the upcoming 2022.1 SDK.
ciao,
Beppe
