Alembic Deformation Motion Blur?
Posted: Sat Jan 29, 2022 12:07 am
by videa
Is it possible to render motion blur with alembic deformation in Octane render?
If so, how do you set it ut?
Re: Alembic Deformation Motion Blur?
Posted: Sun Jan 30, 2022 10:19 am
by juanjgon
If the alembic has a velocity "v" attribute, you can use it to render the motion blur.
Posted: Sun Jan 30, 2022 2:34 pm
by videa
Hi Juanjo, yes the alembic should have velocity data (motion blur renders fine in LW internal render and if I bake the scene and render it in Octane standalone render).
I have added the Octane_object_Properties to the object (didn't know you needed to do that) but it still doesn't render motion blur.
Is there something else I need to do?
I have the same problem with MDD files.
Posted: Wed Feb 02, 2022 11:13 pm
by KVNOODLES
Make sure you've check the Photoreal MoBlur in Lightwave...(LW2015)
Normally, with a true render (F9 or F10) you should have the motionblur visible.
IPR don't render deformation MoBlur. (Only the camera, translation, scale and rotation are supported.)
