Octane Render crashes Houdini/Solaris when switching Engines
Posted: Thu Jan 27, 2022 8:20 pm
Hi there,
I finally managed to get Redshift and Octane Render to run side by side in Houdini's Solaris context. However, it still crashes the app regularly.
Generally speaking I can get Octane to behave predictably if I follow the steps below:
If I run Octane and then want to switch to another engine, e.g. back to Redshift, I have to follow the same steps.
It'd be great, if you could look into that.
- - If I have Redshift running, I need to select "Pause Render" (from dropdown menu)
- - Then select "Houdini GL"(from dropdown menu)
- - Then select "Reset Redshift" (from dropdown menu)
- - Then select "Octane" (from dropdown menu)
- - Select "Pause Render" while running Octane (from dropdown menu)
- - Then select "Reset Octane" (from dropdown menu)
- - Then select "Redshift" (from dropdown menu)
