export Orbx from Archicad to use in MODO?
Posted: Wed Jan 19, 2022 4:35 pm
by Dingbat
i've saved an Orbx file in Archicad which opens and renders as expected in Octane standalone but won't render in MODO
i'm loading the Orbx as a proxy in MODO and have no issues using other Orbx files (also as proxies)
is there some kind of limitation here as the Orbx was exported from Archicad?
Re: export Orbx from Archicad to use in MODO?
Posted: Wed Jan 19, 2022 9:56 pm
by face_off
Hi - what specific issue/error are you getting please? Can you send me the ORBX you are using as the proxy? Which version of the Modo plugin are you using?
Posted: Thu Jan 20, 2022 7:12 pm
by Dingbat
no error as such. i point Octane to an Orbx proxy mesh (same as i would for a plant for e.g) but the proxy exported from AC doesn't render
i just see the background environment and nothing else where the object should be. if i switch to one of my plant proxies (not exported from AC) then everything works as expected
attached is a simple cube (around 5m high/wide), exported from AC as orbx
using MODO 14.2
i need to combine linework from AC with MODO renders. scattering in AC is both clunky and limited so i need to do it in MODO and the easiest way to link the AC model is to simply save it as an orbx and import in MODO as a proxy. then if i need to update the AC model i simply save another orbx and update the MODO scene...
not ideal but it's way quicker than trying to export a model from AC and then dealing with changes to the mesh, to materials and so on
Posted: Fri Jan 21, 2022 5:35 am
by Dingbat
just to confirm, the orbx file renders as expected in Octane standalone
just doesn't render in MODO
Posted: Fri Jan 21, 2022 6:07 am
by face_off
Hi - this is due to a quirk in the way Octane handles Object Layer Maps. I believe OTOY were going to look at a solution at some point. The workaround is to edit the ORBX file in Octane Standalone, and then add a Geometry Out node to the nodegraph and plug in the Mesh node to it. Then render in the Modo plugin.
Posted: Fri Jan 21, 2022 9:18 am
by Dingbat
thanks Paul that works
i've done some quick tests and i think the nodes can be changed directly in MODO, which saves time and hassle
so if anyone else needs to do this:
load the proxy in MODO
click the 'Edit proxy file' button
link the 'Geometry out' node to the 'Mesh' Node
then SAVE the proxy - click the 'Save proxy file' button
Posted: Fri Jan 21, 2022 11:04 pm
by face_off
Yes, that is an even easier way to do it - thanks.
