What have I done?
Posted: Tue Jan 04, 2022 3:50 pm
by haffy
I can't seem to see the whole frame anymore, only when I lock the resolution. What have I done?
Re: What have I done?
Posted: Wed Jan 05, 2022 7:51 am
by bepeg4d
Nothing special
If you zoom out the Live View (0.3 in your case), without the Lock icon active, the aspect ratio is taken from Live View dimensions, so just resize the Live View horizontally, to be able to see the whole frame.
If the Lock icon is active, the aspect ratio is taken from final render dimensions.
ciao,
Beppe
Posted: Fri Jan 07, 2022 11:55 am
by haffy
Thnks bepeg4d
Posted: Wed Jan 12, 2022 2:34 pm
by haffy
It's still happening, must be a bug of some sort.
Posted: Thu Jan 13, 2022 7:53 am
by bepeg4d
It depends from the aspect ratio in render Settings/Output.
Please, when the Lock icon is disabled, resize the Live View horizontally, you should see two lines on top and bottom, defining the vertical limit of the frame.
ciao,
Beppe
Posted: Thu Jan 13, 2022 8:07 am
by haffy
Yes I see them, but that is not them that is limiting. Afte when I have changed from horizontal (1280x720) to vertical (720x1280) back to horizontal, this happends.
Posted: Thu Jan 13, 2022 9:30 am
by haffy
I think there is somthing wrong with my Octane setup, if I change from 2 to 100 samples, there is NO differens at all.
So I reinstalled (removed from plugin and reinstalled the OctaneRender_Enterprise_2021_1_1_win standalone and then the OctaneRender-for-C4D-2021.1.1-R2-win for C4D), but it did not help.
Is there a config file or somthing that I can delete?
Update, I installed S24 instead of R23 and it works fine in there.
Posted: Fri Jan 14, 2022 7:17 am
by bepeg4d
Ok, nice to hear that the plugin is working correctly in S24.
If you want to investigate why R23 is not working as expected, please write to help at otoy dot com, asking for Beppe.
ciao,
Beppe
Posted: Fri Jan 14, 2022 7:41 am
by haffy
bepeg4d wrote:Ok, nice to hear that the plugin is working correctly in S24.
ciao,
Beppe
Thanks bepeg4d! I am fine with s24, so I will let someone els have the super-support
