Camera Match and Octane
Posted: Tue Nov 09, 2021 4:24 pm
by justix
I'm here with an old topic that is now really making my do hard to complete. I need to know if anyone have a valid tip on to get a render out of a perpsective match using vanishing lines set correctly that just disappear on rendering.
Basically the render is totally wrong in a perspective point of view like if the camera does not reflect what I did set on the Perspective Match tool.
The render config is correct set to match the render size output ( makes no different if I match the bitmap ) the render size is set the Photo size in Pixels.
I should be able to render without creating an Octane camera but there is no way to obtain what I set not even using a Physical camera or standard, the result is always incorrect and I don't know if it is matter of Max or Octane at this point, still no way of creating an Octane Camera? Ctrl-C gives me a Physical one. Did also try to LOCK camera info
Re: Camera Match and Octane
Posted: Wed Nov 10, 2021 12:51 pm
by paride4331
Posted: Wed Nov 10, 2021 9:15 pm
by justix
paride4331 wrote:Hi justix,
viewtopic.php?f=81&t=59207&p=303357&hil ... h.#p303357
Thanks but is not use, the Z lines are essential for fixing my model with the bitmap of choice, with XY only is very hard to get a correct image, but even if I use a Physical Camera were I have an option on the Tilt correction the output is incorrect on my render output.
