Page 1 of 2
UV-Mapping doesnt work for Hair Clones
Posted: Tue Nov 09, 2021 9:33 am
by fLuppster
I've go a simple hair setup using a custom map via UV-Mapping for the color of the hair. As soon as i activate the cloning option under Hairs > Cloning, the clones will not use the correct UV-Mapping like the original hair (images attached). Even when i try the C4D hair materials option for that (Color > Roots > Texture), Octane will not render it correctly. C4D Standard Renderer does. So it seems like an Octane limitation to me. Or am i missing something here?
- 3.JPG (23.8 KiB) Viewed 3285 times
Re: UV-Mapping doesnt work for Hair Clones
Posted: Tue Nov 09, 2021 1:16 pm
by aoktar
Tested it's FINE here. Could you please send the SCENE as in FORUM rules at top of this section?
Posted: Tue Nov 09, 2021 4:10 pm
by fLuppster
Yep, sorry. Could you also send your scene please?
Posted: Tue Nov 09, 2021 6:35 pm
by aoktar
fLuppster wrote:Yep, sorry. Could you also send your scene please?
Not a saved scene. Just attached c4d material on a plane with created a hair and changed clones
Posted: Wed Nov 10, 2021 9:48 am
by fLuppster
Well you can see in my scene, that it doesnt work. Two other people could also reproduce it.
You say you attached the material to the plane. Just to make it clear: I dont want to change the color of the plane, but the hair clones.
Posted: Wed Nov 10, 2021 10:45 am
by aoktar
fLuppster wrote:Well you can see in my scene, that it doesnt work. Two other people could also reproduce it.
I'm attaching the same texture to hair material also, it's just for comparing the result;)
Posted: Fri Nov 12, 2021 2:54 pm
by fLuppster
Did you check my c4d file? The hair clones are not using the correct mapping, like the original hair. The setup is pretty basic with default settings. It would be nice to see your setup.
Posted: Fri Nov 12, 2021 3:46 pm
by aoktar
fLuppster wrote:Did you check my c4d file? The hair clones are not using the correct mapping, like the original hair. The setup is pretty basic with default settings. It would be nice to see your setup.
I'm busy for now, will check when finished some work.
Posted: Sat Nov 13, 2021 12:45 pm
by aoktar
see this
Posted: Sat Nov 13, 2021 9:16 pm
by fLuppster
Oh okay, i see. You activated "Set Roots". I tried to avoid that, since it is making hair setups very slow. Any chance to get it working without "Set Roots" activated?
