Octane failed rendering a big scene
Posted: Mon Oct 25, 2021 4:09 pm
by PaGz
Hello :)
I am looking for solutions for my project.
Octane is failed rendering a scene with no textures but zillions of geometry. ( 10 buildings destroyed )
All my dynamic simulations are cached in a single one.
I have a RTX2080 TI with 11 gig memory.
The rendering is starting and take very long time to load the scene in gpu then Houdini crash after about 40 mins :(
I really don't know how i can optimize the scene more than what i did..
Does packing can help? or activating out of core (64 gig RAM on my system )
Re: Octane failed rendering a big scene
Posted: Mon Oct 25, 2021 4:11 pm
by PaGz
Here is the visual..
Posted: Mon Oct 25, 2021 4:17 pm
by juanjgon
Enabling the out-of-core feature is going to help for sure, but you should also be aware that there are limits about the amount of geometry that a single OBJ node can handle.
If you are working with OBJ nodes including several millions of polygons you should think about breaking it into several additional OBJ nodes, importing a set of data into each one. This has two advantages: avoid reaching the Octane limits in the number of data that a single OBJ node can handle, and improve the scene extraction time due to the multi-thread scene extraction feature, which can split the expansion of several OBJ nodes among all your CPU cores.
Hope it helps,
Posted: Mon Oct 25, 2021 5:57 pm
by PaGz
Thanks Juanjgon!
I will try that :)
Please tell me the limit per obj node?
I will give you feedback!
Best
Posted: Mon Oct 25, 2021 6:23 pm
by juanjgon
It is hard to say because it depends on the number of UV maps, user attributes, etc. but I'm sure that a single OBJ node with let's say 50 MPolygons could fail, and the scene extraction time can be very slow.
Posted: Mon Oct 25, 2021 7:09 pm
by PaGz
Thanks again Juanjo!
Now i can render with the IPR! :)
I will now try to render all the sequence.
Best!
Posted: Mon Oct 25, 2021 7:32 pm
by PaGz
Yay!!!
Thanks you so much!
Posted: Mon Oct 25, 2021 9:14 pm
by juanjgon
Great! I'm glad your scene can be rendered now.
Posted: Tue Oct 26, 2021 4:37 pm
by PaGz
I've been able to render all the frames last night :)
