Orx and ocs export with animation
Posted: Fri Aug 13, 2021 10:53 am
by marchermitte
Hello.
I know I've done that a while back... I can't remember how to export everything (mdd/bones deformation, animation etc) from lightwave to Octane stand alone using ORBX or OCS
Also, is there a way to export several cameras (if several are animated in the same scene) and switch in octane standalone the rendering camera within the same scene? Or Do I have to dekete any other camera in Lightwave and export a specific orbx/ocs for each cam?
Thank you
Re: Orx and ocs export with animation
Posted: Fri Aug 13, 2021 1:42 pm
by juanjgon
To export an animated .orbx you need to enable the export options in the render target root node options panel and press F10 to render the scene to disk. Be aware that only can export animated .orbx files in "scene update" rendering mode. I don't think that exporting several cameras can be possible, but you could try it.
Posted: Fri Aug 13, 2021 2:01 pm
by marchermitte
Ah, that means that I have to render the scene first in lightywave? With the same settings that are going to be used in Standalone Octane?
Posted: Fri Aug 13, 2021 2:15 pm
by juanjgon
When you enable the scene export options and press F10, the scene is not rendered, it is exported to the .orbx file that later you can load in Standalone.
Posted: Fri Aug 13, 2021 2:58 pm
by marchermitte
Ok thank you.
I just remembered that the last time I tried, It was with Octane for Modo (not Lightwave) and there was a specific command to type to be able to export orbx with animation.
Posted: Fri Aug 13, 2021 3:19 pm
by marchermitte
I works well. In Octane, do I need to connect the batch render job node to the render target? There are 3 impute, I need to reduce to 1 in the render taret count or do I need one for the main image, and one for each pass?
Amd how do i start rendering the amination?
Not much in the doc..
Thank you
Posted: Fri Aug 13, 2021 3:35 pm
by marchermitte
F...! I just found. right click on the batch render mode.
Man, sincerily, Is It so hard to have a proper detailed documentation or a nice render animation button?
Easy when you know how It works but definitly not intuitive.
Thank you Juangon (sorry, I was not "blaming" you at all)
