AI Up-Sampler and C4D Denoiser problem
Posted: Tue Jul 20, 2021 6:47 am
by Delizade
After 3 hours of struggling here is the result
1) if scene is rendered with AI Up-Sampler C4D native denoiser is processed but not effects on final image result
2) if AI up-sampling checkbox is unchecked, same problem occurs. Up-sampling mode has to be "no up sampling" as well.
3) mainly if Up-sampling mode is "no up sampling", denoiser is being processed and effects final image.
C4D 23.110
Octane 2020.2.4-R2
ACES workflow
Re: AI Up-Sampler and C4D Denoiser problem
Posted: Mon Jul 26, 2021 10:21 pm
by Delizade
hello everyone,
Still I couldn't solve this problem so any idea about that will be helpful.
Posted: Wed Jul 28, 2021 8:20 am
by Delizade
hi,
is there any solution for this problem?
Posted: Tue Aug 03, 2021 11:14 am
by Delizade
hi again,sorry for my repetitive posts but I have to render my scene and with AI sampler I save 3 minutes for a single frame. As mention before I've tried to make render with high samples + Octane Denoiser solution rather than Intel denoiser but I couldnt get good result sadly.
So I have to solve this problem. Why if I use AI Sampler C4D denoiser does not effect output file? It runs but saved image is not denoised.
is there anyone who experience this? or is there any idea?
thank you
Posted: Tue Aug 03, 2021 11:23 am
by aoktar
Delizade wrote:hi again,sorry for my repetitive posts but I have to render my scene and with AI sampler I save 3 minutes for a single frame. As mention before I've tried to make render with high samples + Octane Denoiser solution rather than Intel denoiser but I couldnt get good result sadly.
thank you
Denoiser modules require some extra data, not just rgb pixels. There's not any communication to C4D denoiser. That's probably the why you don't see any expected results.
Posted: Tue Aug 03, 2021 11:55 am
by Delizade
thank you for information.
Without AI up sampling c4d denoiser works if it is used, doesn't. So in this case if AI-Up Sampling is used those data can't be used by c4d denoiser? and I assume that there is no cure for that did I understand correctly?
Posted: Mon Aug 09, 2021 3:47 pm
by Delizade
without AI-UpS + C4D Denoiser.
AI_upsampler&c4dDenoiserIssue.zip
test scene
(9.5 MiB) Downloaded 221 times
latest test files are attached
