OctaneRender 2020.2 LightWave Production build 2020.2.4.0
juanjgon
wavesoflight wrote:
slv wrote:Hi All, i confirm that i get crash of lightwave with this latest version of plugin. Crash when multi thread extraction is enable with instances. if i disable multithread extraction , render IPR run correctly !
This on this old scene as exemple ( with lw plugin 2020.2.3.1 i have no problem )
How do you turn off Multi Thread extraction please?
There is an option in the plugin options panel to disable it.
wavesoflight
Thanks man.
wavesoflight
Hello again.
Multi threading extraction results in F9 or F10 complete freeze - It loads the preview window and then nothing, you have to kill Layout and reload. IPR still works.
I did manage to get it to work with just a fresh scene and using Modeler tools within Layout to make a simple cube. But if I load any objects into the scene with MTE on, F9 and F10 freeze.
I'm using LW2015.3
artecnl
pixelsmack wrote:One thing I have found. This seems to only be happening on the 32-core/64 threadripper. The 24-core/48 threadripper wasn’t doing this.. I will disable multi thread scene extraction and see if this is a possible cause.
Having the same issue Here, i have a 1950x threadripper only with this new relase. in Multithread extraction, some objects drop in the scene. i have 2x 3090rtx and LW 2020.0.1
promity
I just can't get Ostan to work with denoise on this scene. Here is the log file.
octane.log
(1.49 MiB) Downloaded 224 times
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
jsboudreau
artzgodka wrote:I found the bug.
I have box, copy the box turn off in scene editor but Octane still render this box.
In the earlier version of Octane there was no problem.
I found the solution to this bug. If you go into the render target node and turn off Instance LW Clones that fixes the issue.
Hope this helps
Jason
Lewis
Yeah clones as instances needs to be off for that but I am not sure that is pure solution. Was that same before on previous octane versions or 2020.4.0 only?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
jsboudreau
Hi Juanjgon,
Wondering when the multi-Threaded extraction crashing is going to be fixed? Right now in the latest versions of Octane it's completely un usable since every time I open the IPR window layout crashes. But if I turn off the multi-threaded extraction it doesn't crash anymore.
Jason
dmodric
Check your models for older materials, missing images etc. I have found that some models crash the render with multi threaded extraction on some configurations. I have desktop which loads the scene and my laptop with the same scene crashes. Cleaning the models helped to load the scene.
__________
AMD3600/X570/64GB/2x2070S
ASUS ROG Strix SCAR 17 G733 AMDRyzen7/64GB/3080 16GB
Carlos3D
scooternva wrote:
promity wrote:Thank you, Juanjgon! It is a pity, however, that spotlight is not available yet. It would be very useful to me now )
C4D and other plugins have had a spotlight for years now. It's feature parity issues like this--not to mention the ridiculous years-long documentation problem--that aggravate me enough to make me wander over to the Redshift site when I'm waiting for an Octane job to finish.
R:I think Octane for LW is one of the favourites, but I agree not to update the manual.
