Page 1 of 3
OctaneRender 2021 for Rhino (OBSOLETE)
Posted: Fri May 28, 2021 5:01 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Rhino - TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you have the latest Rhino Service Release installed.
3) If you get an "Error Starting Octane - Could not load OctaneWrapper?.dll" error when installing the plugin, this is generally due to not having the latest NVIDIA drivers installed (so see Solution 1) above.
4) If you get a "Package not compatible" error when installing the plugin, please follow the instructions at https://wiki.mcneel.com/rhino/5/rhi-problems -> "Package not compatible".
5) If you get an "Unable to load OctaneRenderForRhino.rhp plugin: initialization failed" error when starting the plugin, delete the HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0\Plug-Ins\F109BD23-4CF3-4C0B-9F83-06BE474B0152 and HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros\6.0\Plug-Ins\F109BD23-4CF3-4C0B-9F83-06BE474B0152 registry entries using Regedit and then reinstall the plugin. If this does not resolve the problem, delete HKEY_CURRENT_USER\Software\McNeel\Rhinoceros from the registry and then reinstall the plugin.
6) If you get an "OctaneRender for Rhino not activated." error when rendering via the Rhino->Render->Render menu, open the plugin Setup window via the OctaneRenderForRhino command, or by adding the plugin panel to the Rhino Properties window as per https://docs.otoy.com/RhinoH/RhinoPlugi ... oceros.htm.
7) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin
8) The Octane Viewport does not appear after clicking the Open Viewport button. This occurs when the Viewport was previous closed on a second monitor, or off the current screen. To resolve this, delete the plugin configuration file config.xml as per https://docs.otoy.com/RhinoH/RhinoPlugi ... ration.htm.
9) LiveDb materials containing OSL nodes will not load into the plugin correctly. The plugin does not currently support OSL Projection or Texture nodes. Instead, copy these Livedb materials into the clipboard from Octane Standalone and paste them into a NodeGraph material in the plugin.
10) Where is the macOS version? I have done quite a lot of work investigating a macOS version of the plugin for Rhino. Unfortunately the macOS UI that Rhino uses offers far fewer controls than the Windows version, and I don't think it's possible to replicate the tree structure that the plugin uses in Windows. So I think it would require a complete re-write of the plugin in order for it to work on macOS, and I don't think that would be possible in the near future.
11) If when rendering with Octane 2021, the render appears to be using a different color map, set the Kernel->White Light Spectrum to Legacy/Flat to render as per Octane 2020.
12) Rhino locks-up/freezes when loading a .3dm containing Octane data. This is due to the plugin searching through very large (or invalid) folders searching for missing texturemaps. To resolve this, delete the plugin configuration file config.xml as per https://docs.otoy.com/RhinoH/RhinoPlugi ... ration.htm.
Rhino Version
This version requires Rhino6, SR34 or later or Rhino 7 version 7.4.21078.1001 or later, on Windows. MacOSX is not currently supported.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 451 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Rhino version and build number
- OctaneRender for Rhino version (ie. 2.0.10.8)
For more information
- Watch Iceglance's quickstart tutorial http://render.otoy.com/forum/viewtopic.php?f=51&t=36299
- Read the on-line manual
- Watch the "Getting Started" video http://vimeo.com/73202740
- NodeGraph material tutorial - https://youtu.be/Yd7jkAnRZpg
- Shadow Passes tutorial - https://youtu.be/ozW98ZjeXYM
- Exporting from Bongo to Octane Standalone - https://vimeo.com/116603709
- Camera Motion Blur in OctaneRender for Rhino - https://vimeo.com/90721378
- Rhino HDRLS integration with OctaneRender - https://vimeo.com/104381431
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Specific Octane 2021 plugin tutorials
Render Passes
Known Issues
- Prior to rendering a Sun Study, Flythru Animation or Bongo Animation, you must select the Perspective Viewport in Rhino that the animation uses
Download Links
NOTE: Rhino files saved with this version of the plugin may not open with the Octane 2020 or previous versions of the plugin.
Current STABLE build (Octane 2021.1.4)
Previous STABLE build (Octane 2021.1.3)
Release Notes
2021.1.4.132 (8-Apr-2022)
- Compiled with Octane 2021.1.4
- Fixed issue where LUT files could not be loaded (issue introduced in 2021.1.2.131)
2021.1.3.131 (7-Mar-2022)
- Compiled with Octane 2021.1.3
2021.1.2.131 (17-Feb-2022)
- Compiled with Octane 2021.1.2
- Fixed issue where non-Octane materials were rendering with a gamma of 1 instead of 2.2 (issue introduced in 2021.1.0.127)
2021.1.0.130 (8-Nov-2021)
- Fixed issue where the Visible Environment node could not be disconnected
- Fixed issue where the Octane Bump map was being used as the Diffuse map in the Rhino viewport
2021.1.0.129 (21-Sep-2021)
- Compiled with Octane 2021.1 RC2
- Fixed issue where saving to Multi-Layer files was not saving layers other than the Beauty layer.
- Fixed exception when using the Rhino->Render command with Octane render and an active clipping plane
2021.1.0.128 (6-Jul-2021)
- Compiled with Octane 2021.1 XB3
2021.1.0.127 (28-May-2021)
- Compiled with Octane 2021.1 XB1
- Added additional error checking when opening the Viewport to capture instances of the "Object reference not set to an instance of an object" error
- IMPORTANT: In line with Octane 2021.1, the Rendertarget->Render Passes pin is now called "Render AOV's". This will default to the pre-Octane 2021.1 Render Passes node, however you can now change this node to a "Render AOV group" node and use the new Octane 2021.1 render pass system
- The Compositor nodes from Octane 2020.2 have been enabled in this release (via the Rendertarget->AOV Output Group pin)
- The following features from viewtopic.php?f=33&t=77764 are now supported by the plugin:
... Improved RTX support
... Interpolated surface tangents
... Clipping material
... Energy preserving GGX BRDF
... Improved hair material
... Improved AI light
... New texture nodes
... New projection nodes
... Refactored render AOVs
... Custom AOVs
... Global texture AOVs
... New output AOVs
- The following features from viewtopic.php?f=33&t=77764 are NOT supported by the plugin (however most are supported if you import an ORBX proxies with the feature):
... SDF from mesh
... Improved Scatter on surface
... Volume rendering
... Improved color processing
- Any nodes which allows "dynamic pins" now have "Add" and "Remove" pins rather than a fix number of inputs. Nodes in this category are:
... AOV output group
... Material layer group
... Composite texture
... Composite AOV output
... Layered material
... Render AOV group
... Composite material
... Gradient map texture
... Toon ramp
... Volume gradient
Re: OctaneRender 2021 for Rhino (TEST and STABLE)
Posted: Mon Jun 07, 2021 11:52 am
by v-cube
Thanks Paul,
this sounds cool, especially the clipping material!
Posted: Mon Jun 07, 2021 12:20 pm
by v-cube
clipping material is not working... disappointing...
I think it is (partly?) not working in areas where 2 elements are sharing the same coplanar surfaces, e.g. a window frame build into a wall
Changing rayepsilon does not change anything...
such a shame, this could have been useful
Posted: Tue Jun 08, 2021 11:39 pm
by face_off
May I suggest exporting the scene to ORBX and sending it to OTOY who can take a closer look.
Posted: Wed Jun 09, 2021 12:05 pm
by v-cube
yes, sorry you are right... I was just disappointed
Posted: Tue Jul 06, 2021 2:09 am
by face_off
I have updated the installers at the top of this thread with:
2021.1.0.128
Posted: Wed Sep 01, 2021 4:03 am
by franchais
Hi Paul, just a question is the rhino physically based materials supported for octane at the moment?
can't seem to get it working.
Posted: Wed Sep 01, 2021 4:47 am
by face_off
franchais wrote:Hi Paul, just a question is the rhino physically based materials supported for octane at the moment?
This is not yet supported. I have pinged McNeel for assistance (https://discourse.mcneel.com/t/rhinocom ... als/129542).
Posted: Wed Sep 01, 2021 5:03 am
by franchais
Fantastic thanks!
Posted: Mon Sep 06, 2021 1:32 am
by face_off
Fantastic thanks!
Hi - I have the plugin able to read the Rhino PhysicallyBased material properties (which are https://developer.rhino3d.com/api/Rhino ... yBased.htm). What would you like the plugin do with these? It could simply use the BaseColor as the Octane Glossy Material "Diffuse" color. Or it could create an Octane Universal Material and also use the Metallic property - however I would ask that you provide the exact conversion formulas that you want in this case (ie. which PhysicallyBased based properies map to which Octane Universal Material pins, and if there is a formula to apply to that mapping.
