Render Layer ID & Render Layer Mask broken?
Posted: Wed May 26, 2021 7:50 am
by TheImageFaculty
Hi Paul,
I am having trouble getting these two passes to work. Versions;
WIN / MODO 14.2v2 / 2020.2.3.170 Enterprise
WIN / MODO 15.0v1 / 2020.2.3.170 Enterprise
When viewed through the Select Render Pass option, or saved as a multilayer exr, these passes do not seem to be working.
It seems that the ID only renders Red/ID01 and the render layer mask only shows the initial layer.
Here is a simple scene to test;
http://share.theimagefaculty.com/_dpxNBlkBE1EsRR
Maybe I'm doing something wrong?
Thx,
D
Re: Render Layer ID & Render Layer Mask broken?
Posted: Wed May 26, 2021 10:44 am
by face_off
Hi.
Render Layer Id worked fine for me when rendering your scene. Render Layer Mask needs Octane Render Passes->Render Layer tab->Enabled ticked.
I hope that helps.
Posted: Wed May 26, 2021 12:31 pm
by TheImageFaculty
Hi Paul,
So when you view the Render ID pass, your seeing different coloured objects based on their Octane / Render Layer id value ?
I see only red :(
D
Posted: Wed May 26, 2021 10:19 pm
by funk
Im testing in 2020.2.3.171 and its working. Grab the latest build from here viewtopic.php?f=34&t=73539
Posted: Tue Jun 01, 2021 11:41 am
by TheImageFaculty
Thanks for the input Funk.
Yes I can confirm that updating works. This also fixed an issue with objects not being hidden from the camera when Octane properties / Camera visibility is unchecked.
Thanks guys,
D
