Octane Solaris plugin 2020.2.3.0 - 05-18-21[OBSOLETE]
Posted: Thu May 20, 2021 4:23 am
by BK
Dear Octane community,
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2020.2.3 - for Houdini 18.5.532.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launch it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
- Changes since 2020.2.3.0 - 05-06-21-
  • Implemented OpenVDB and Octane geometry settings inside Render geometry settings tab. (Motion blur feature yet to support)
  • Implemented Show Octane window and Show Octane Log option for diagnostic
  • Other bug fixes
-Known Issues-
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
Enterprise Subscription Downloads
2020.2.1.3 Houdini 18.5.532
OctaneX PR11 Houdini 18.5.532
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
Re: Octane Solaris plugin 2020.2.3.0 - 05-18-21
Posted: Fri May 21, 2021 6:42 pm
by rohandalvi
The dome light rotation issue still remains. every time I rotate the dome light , the lighting in the viewport resets. Then I need to switch to karma and come back to the see the lighting update. This also happens if I change any parameter in the dome light.
Posted: Mon May 24, 2021 3:43 am
by BK
rohandalvi wrote:Hi,
Hi Rohan,
Thank you so much for reporting this issue.
We are able to replicate it on our end, hopefully, we will get it fixed in the upcoming release.
cheers
