walk through
JNDesign
Hi Paul
Do you know if the plugin now supports animation?
I think it was broken in ver 19 on wards....
We are stuck so any help will be appreciated
cheers
Hi
Sorry, I am not sure yet. It will take some work to get this feature running again (if that's possible), as the way the buttons work (internally) in Revit on the ribbon bar has changed, so the plugin cannot just press the Next Frame button to advance the animation. I will be doing the Octane 2022.1 version of the Revit plugin in a month or two, so will investigate the issue further then.
JNDesign
Thanks Paul
From memory, the controls are still the same at user end however dont know about the programming side of things if they broke it between versions.
We would love you to look into this at your earliest as its a major part of our Revit workflow.
Cheers
Return to “Autodesk Revit”
