Start Rendering Hangup
Posted: Fri Apr 23, 2021 3:08 am
by Sen3
When I render my scene out, after each frame, it hangs on the "Start Rendering" for over a minute.
Anyone come across this issue?
OS: Windows 10
GPU 2 - 3090
RAM Capacity 128GB
Nvidia driver version: Studio 462.31
OctaneRender Standalone version: 2020.2.3
OctaneRender plugin version: 2020.2.3-R2
Host application version: C4D R23
Re: Start Rendering Hangup
Posted: Fri Apr 23, 2021 5:58 am
by bepeg4d
It depends on what you have in the scene, and from the Geometry Engine, and Controls parameters in Render Settings/OctaneRender/Main tab.
Please run the scene in Picture Viewer, then press SHIFT+F10, and share a complete scrteenshot of the interface, showing also the Render Settings/OctaneRender/Main tab panel, thanks.
ciao Beppe
Posted: Fri Apr 23, 2021 8:51 pm
by Sen3
Attached the files.
This is while it's updating in the Live Viewer, takes about a minute or more when changing something, plus it slows down Cinema as a whole
Hope this helps
Edit: Added another Bug Report
Posted: Sat Apr 24, 2021 7:36 am
by aoktar
Your info is having nothing useful. Please follow your post for getting help.
1-Apply the steps in the picture and send the required file.
2-Record a full screen capture while (Extensions Menu/Console) is open
3-PM the your scene which is causing the issue
OR, if you're hesitating to share anything
1-Delete some content until crashes are stopped and find the what's causing the crashes.
