Hi!
You're applying your change globally. You need to turn on animated sculpting by clicking on the "curve" icon of the Morph Shape attribute, like showed here:
https://youtu.be/FztXewLP1Zg?t=175
That way you'll be able to make changes "locally" and properly interpolate those with the original cache.
I hope this helps!
Thanks!
Sculptron 1.1 with Alembic support!
- Rikk The Gaijin
Oh ok, yeah now it kinda works. The interpolation doesn't seem to do a great job however. I basically have to smooth every single frame, because it doesn't really interpolate like I would expect.
Also, is there a way to show the mesh with Double Sided faces?
- linograndiotoy
You need to create keyframes at "startegic" positions. If you need to smooth the mesh at frame 50, for example, you may have to also create keyframes at frame 45 and 55 (preserving the original shape in those frames) to get a good interpolation.Rikk The Gaijin wrote:Oh ok, yeah now it kinda works. The interpolation doesn't seem to do a great job however. I basically have to smooth every single frame, because it doesn't really interpolate like I would expect.
About Double Side support, that's not possible in the current version, but it's already been implemented in the build we're currently developing.
- edan_lusion
First time installed and it says "Your trial period has ended"
- thefacesblur
this is happening to me also. it used to work. i've got an active studio subscription. what's going on team?edan_lusion wrote:First time installed and it says "Your trial period has ended"
- linograndiotoy
We'll investigate the issue so we can solve it! Thanks for your patience.
- linograndiotoy
The issue should be fixed now! Please download the installer again from your OTOY account.
Thanks!
Thanks!
