directional light
Posted: Wed Mar 24, 2021 3:23 pm
by jwfvr
it seems like there is an issue with directional lights if added in - if I use the default directional light, everything works as it should, but if you delete the original directional light from your scene, then add one back, nothing works - the light appears, aiming straight down, but you can't change anything about it - it does not respond at all - I have the env set to lighting env and the octane setting is on daylight - am I missing something?
Re: directional light
Posted: Wed Mar 24, 2021 10:12 pm
by face_off
jwfvr wrote:it seems like there is an issue with directional lights if added in - if I use the default directional light, everything works as it should, but if you delete the original directional light from your scene, then add one back, nothing works - the light appears, aiming straight down, but you can't change anything about it - it does not respond at all - I have the env set to lighting env and the octane setting is on daylight - am I missing something?
If you refresh the Viewport does the new light work?
Posted: Thu Mar 25, 2021 1:48 am
by jwfvr
no - refresh or restart does not fix it. I just tested it some more thinking I missed something but its being very consistent - any ideas?
Posted: Thu Mar 25, 2021 1:49 am
by funk
You need to select the environment material > set "sun light" = (your new directional light)
It's mentioned in the docs, under "Sun Selection and Direction"
https://docs.otoy.com/ModoH/ModoPluginM ... onment.htm
Posted: Thu Mar 25, 2021 1:51 am
by jwfvr
awesome!! thankyou!! don't think I have ever had to go there before...
