Live Viewer vs Picture Viewer
Posted: Wed Dec 09, 2020 7:25 am
by BakerImageGroup
I've checked everything I could fine but I can't get my live viewer to match output in Picture Viewer.
Any ideas?
2019.1.5
Re: Live Viewer vs Picture Viewer
Posted: Wed Dec 09, 2020 12:46 pm
by lanklaf
Any ideas?
2019.1.5
Change the Render buffer type from Float (linear) to Float (tonemapped).
Float (linear) does not store any camera settings.
Posted: Thu Dec 17, 2020 11:00 am
by madmandrax_1
I have the same problem. Render Buffer Type is set to Float (tonemapped), the liveviewer setting is set to HDR tonemapped. Any ideas?
Posted: Thu Dec 17, 2020 12:00 pm
by aoktar
madmandrax_1 wrote:I have the same problem. Render Buffer Type is set to Float (tonemapped), the liveviewer setting is set to HDR tonemapped. Any ideas?
Put your scene without any content, just current camera and keep render settings. Then I'll say what's wrong
Posted: Fri Dec 18, 2020 1:32 pm
by madmandrax_1
Thanks, find the project file attached.
Posted: Mon Dec 21, 2020 8:51 am
by bepeg4d
Hi madmandrax_1,
you have not shared the HDRI, so the light cannot be the same, anyway, please avoid to mix OctaneRender settings with other render engines settings:
And set the Geometry Engine to “All objects movable”:
Looking forward for your feedback,
ciao Beppe
Posted: Mon Dec 21, 2020 10:14 am
by aoktar
Deprecated options are meaning they will be removed sometime later.
Also, disable "use denoised beauty pass" for trying. Render passes are linear by default.
Posted: Tue Dec 22, 2020 7:25 pm
by madmandrax_1
Thanks Beppe! Delecting the unused render setting sections did the trick. I'm surprised, that unchecked render options have that much effect. Now my picture viewer and live viewer output is almost identical.
