OctaneRender® for 3ds max® v2020.1.5 - 10.20
paride4331
Templas wrote:I have a question why the ZDepth channel looks good when rendered, but when saved, it becomes striped
Hi Templas,
it seems to work fine.
try to take a look at my setting.
Regards
Paride
01test.rar
(753.74 KiB) Downloaded 328 times
Templas
Hi Templas,
Regards
Paride
Thanks. That helped )
DartFrog
I'm not sure if this is a bug, or just the way Clay Mode works, but all lights are always visible no matter what. I have visibility checked off, as well as visible to camera unchecked and visibility set to zero on each lights octane preferences. Any chance of this being changed or fixed in the future?
Thank you!
paride4331
Hi Dartgrog,
did you set "hide" in Octane properties panel?
Regards
Paride
DartFrog
paride4331 wrote:Hi Dartgrog,
Regards
Paride
Hi Paride, If I check hide in the octane object properties, the lights won't render at all. So I'm either able to have the lights affect the scene but be forced to have their geometry visible, or hide them completely losing all of the light they would produce in the scene otherwise.
