Fireflies HDR
Posted: Wed Mar 17, 2010 3:15 am
by ltchest
So, are these fireflies unavoidable when using HDR lighting ?
Can you add a texture as a background image without it lighting the scene ?
Re: Fireflies HDR
Posted: Wed Mar 17, 2010 7:44 am
by Sam
These fireflies are here because of the lack of MLT currently.
You can improve by checking your roughness ammount on glossy materials (if lower than 120 = fireflies)
With the mesh emmiters it will be possible to light the scene without using an HDRI at all
Re: Fireflies HDR
Posted: Wed Mar 17, 2010 12:16 pm
by radiance
these are indeed normal, but the amount in your render is way too much,
so as Sam said, check your glossy materials roughness > 80 minimum and also see if you have any glass materials with wrong normals.
you should be able to find the culprit fairly quickly with some experimentation on the materials.
Radiance
