				Smoke Domain remains visible in render view
				Posted: Thu Oct 08, 2020 11:51 am
				by Whispermode
				Hello.
I've created a smoke simulation.
In render view, the domain (box) renders as well.
I'm in 2020.1.4, have a Volume Medium connected to the Volume pin on the output, and no surface material.
Any ideas? It's driving me a bit crazy.
				Re: Smoke Domain remains visible in render view
				Posted: Thu Oct 08, 2020 3:22 pm
				by Whispermode
				UPDATE: the problem seems to occur only with the 'Quick Smoke' implementation - creating a domain and flow object manually, works just fine.
...so not the end of the world, but probably needs fixing.
				Posted: Thu Oct 08, 2020 4:43 pm
				by linograndiotoy
				Can you please share a simple scene showing the issue?
As an advice, do not use the Quick Smoke option to setup your object fro simulation. Doing it "manually" should solve the issue.
				Posted: Thu Oct 08, 2020 7:15 pm
				by linograndiotoy
				Oh, it looks like I answered after you found the solution already.
Right now all "Quick" commands shouldn't be used when using Octane.
We'll see if and when we'll be able to make our own versions of the commands.
