Black "artifacts" on render when using transparent textures
Posted: Sun Sep 13, 2020 11:35 pm
by Corey3D
Hello,
Any idea what might be causing these black "artifacts"? I am using Blender 2.83 with Octane.
I just apply the transparent texture to the Opacity in an Universal Material node.
Re: Black "artifacts" on render when using transparent textures
Posted: Mon Sep 14, 2020 6:25 am
by bepeg4d
please check the scale of your project, probably it is off.
You should be able to correct the issue by changing the Ray Epsilon value in Kernel settings, that defines the precision of the rays.
ciao Beppe
Posted: Mon Sep 14, 2020 3:33 pm
by Corey3D
Thank you very much!
Changing scale and decreasing "Ray Epsilon" solved the problem.
