animation from point cache
Posted: Sun Aug 23, 2020 2:06 pm
by jimho
I have a question on the animation, I've tried to search on the forum yet not find any information,
if the animated items are made in a way of point cache(e.g. trees blowing by the wind), is there a way to export them to orbix?
I tried but I can only get still one.
is there anyway to get them translated into animated abc etc, or it is just impossible?
Thanks in advance.
Re: animation from point cache
Posted: Tue Aug 25, 2020 1:42 pm
by paride4331
Hi jimbo,
Yes, you can export your point cache animation to .orbx.
Don't forget to select "export" and Enable Abc Export.
Posted: Wed Aug 26, 2020 5:33 am
by jimho
Thanks Paride, for your respond,
but confusingly, it seems I did exactly as you mentioned, but I only get still orbx:
Probably I am missing anything?
Thanks again.
Jim
Posted: Wed Aug 26, 2020 6:47 am
by paride4331
Hi jimho,
you should have the animation timeline like in my screenshot.
Could you try to export again changing the .orbx name?
Posted: Wed Aug 26, 2020 12:09 pm
by jimho
I did this in 3dsmax 2018,the timeline donot appear, then I turn to 3dsmax 2020 the timeline appears,both are with the latest octane plugin,
the problem might comes from a bug from 3dsmax 2018.
but there is still issues when I export from 2020, though there is a timeline, it is still not an animation, there is 25 frames but actually all the same not moving at all
Posted: Wed Aug 26, 2020 12:56 pm
by jimho
there is no frames stored in the abc file.
Posted: Wed Aug 26, 2020 1:57 pm
by paride4331
jimho wrote:there is no frames stored in the abc file.
Hi jimho,
it works with 3dsmax 2021, but you're right some issue exporting to .orbx.
I will investigate about.
Posted: Wed Aug 26, 2020 7:46 pm
by jimho
I tried 2021, it appears same as 2018,no timeline,no frames appears in the abc,
I almost have everything default,guess we are using the same file,is there any setup you have changed?
Posted: Thu Aug 27, 2020 1:58 am
by neonZorglub
jimho wrote:I tried 2021, it appears same as 2018,no timeline,no frames appears in the abc,
Hi jimho,
It could be that you didn't set the animated objects as Movable Proxy (Octane object properties)
Here is the steps I did:
-open Octane User settings from the Octane menu; Preset menu : choose Reset default settings
-open AM171_005_anim_Vray.max
-set Octane as renderer
-set AM171_005 as movable proxy
-change viewport from Orthographic to Perspective
-Render setup, Tools tab, Octane export Rollup:
enable Animation, set End frame to 50
Export
This creates an orbx file of ~30.5 MB
Note that without setting AM171_005 as movable proxy, the animation will not be exported, and the resulting orbx file is ~ 17.2 MB
I hope that helps,
Posted: Thu Aug 27, 2020 3:28 am
by jimho
Wow, This is exactly the problem comes from,
Thank you so much both of you neonZorglub and paride,Thanks!
