octane osl projection no inputs
Posted: Fri Aug 07, 2020 10:05 am
Hi everybody, i want to use the uv randomizer script. my problem is that when I load the script in the osl texture node, everything works as expected, i got all my inputs to put textures into it. But the output is a texture output and not a projection as needed.
I tested the octane projection node in "osl-projection" mode, everything compiles but I can't get any inputs to show up on the node. Any advice would be awesome
Cheers!
Cheers!
