NEW: Octane X - is finally here! [MEGA FAQ THREAD]
mestacio wrote:I installed Octane X on my iPad but when I open it, it says unsupported GPU found. I have an 8th gen iPad with the A12 chip in it. The page on the app store says Octane is supposed to be compatible with the A12 Bionic chip. What is going on?
iPadOS 18.3.1 / iPad 8th Generation / Apple A12 Bionic
please avoid cross posting, I have already answered you here:
viewtopic.php?f=9&t=84618#p438277
ciao,
Beppe
dsol21
I've finally made the Apple Silicon transition for my main workstation and now running a very nice M4 Max system. I'm trying to get Octane on there (with Cinema 4D) and it doesn't seem to be working. I've downloaded the plugins and installed them into the C4D plugins folder, but nothing shows up when I open up Cinema. Is there anything else I need to do? This in in Cinema 4D 2026.0
Any help massively appreciated!
Please note that you need to have macOS 15 Sequoia installed, or plugin cannot work.
The devs are finishing to work on new OctaneRender version supporting new macOS 26 Tahoe, and should be published shortly.
For C4D 2026, you need at least c4doctane 2025.3-v1.7.1:
https://render.otoy.com/plugindownloads/0c/a6/48/e0/OctaneRender_Prime_2025.3_for_Cinema4D_v1.7.1.zip
Note that you always need to remove from the OctaneRender folder, all the unnecessary c4doctane-R2X.xdlib files not related with R2X specific version, and leave only one c4doctane-R2X.xdlib file in ../plugins/OctaneRender directory.
ciao,
Beppe
dsol21
Thanks for responding. I'm running Sequoia (15.6.1) and the plugins are installed in the correct location, as far as I'm aware (without duplicates for the wrong version of C4D). Here's a screen grab of the directory showing them in place:
Image(Link)
But when C4D starts up, there's no sign of Octane. Is there any way to show a list of active plugins in C4D? The preferences pane only shows the directories added
cjadams
Pretty sure the plugin needs to go in the other “plugin directory” not the C4d one. - should be over in the directory below “see attached”
dsol21 wrote: Fri Oct 10, 2025 1:37 pm Thanks for responding. I'm running Sequoia (15.6.1) and the plugins are installed in the correct location, as far as I'm aware (without duplicates for the wrong version of C4D). Here's a screen grab of the directory showing them in place:
Image(Link)
The installation path is the correct and preferred one.
If you install it in Preferences path it is user dependent.
The issue is that you have kept the wrong .xlib file for C4D R26, instead of 2026:
ciao,
Beppe
New Standalone for OctaneRender version 2025.4 has been released:
https://render.otoy.com/octane_eula_only_downloads/000_obd/265/e5752eac/fa/0e/bb/38/Octane_X_Prime_2025_4_macos.dmg
This is the first OctaneRender version supporting macOS 26 Tahoe.
Plugins will follow asap.
ciao,
Beppe
dsol21
bepeg4d wrote: Mon Oct 13, 2025 7:19 am The installation path is the correct and preferred one.
ciao,
Beppe
Ah brilliant! Thank you Beppe. I should have looked more closely :)
erdincaydin
Merhaba OTOY Ekibi,
macOS 15 “Tahoe” üzerinde Mac Studio M3 Ultra (80 GPU çekirdeği, 512 GB bellek) kullanıyorum.
Octane X 2025.4 sorunsuz çalışıyor; ancak macOS için Network Render Node halen Monterey/PR14 göründüğü için sürümler eşleşmiyor.
• Tahoe uyumlu macOS (Metal) Network Render Node (PR15 / 2025.x) için tahmini tarih var mı?
• Eğer herkese açık bir test sürümü varsa, erken test grubuna katılmak isterim.
Teşekkürler!
— Erdinç Aydın
juhatakabe
bepeg4d wrote: Mon Oct 13, 2025 7:21 am New Standalone for OctaneRender version 2025.4 has been released:
ciao,
Beppe
Nice! I was just checking if Octane would be Tahoe compatible already. I will wait for Houdini update, thanks!
Houdini 21
Win / RTX4090
Mac / M4 Max
