OctaneRender 2020.1 LightWave Production build 2020.1.3.0
promity
Surprisingly not so much - about 9 gigabytes of the allocated 32. at the same time LW consumes 50 gigabytes on this scene.
But the buffer loading takes about 6-8 minutes for Octane. And if you use LW native renderer, the loading is done in less than a minute.
BTW, the scene is - https://www.nonecg.com/3D-products/tokyo-shibuya/ - very good test for hardware.
The scene for 3DMax's looks like this. But for the LW (I was working for the NONECG), I've optimized it and converted most of the trees into instances.
Additional information.png (10.6 KiB) Viewed 3456 times
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Hi Juan, the annotation for the new release of the Octane 2020.1.4 says the following:
Fixed a crash on Windows 7 when upsampling was enabled.
Could you confirm that in a plugin for LW this function will also work under Windows 7?
Lightwave 3d
juanjgon
promity wrote:Hi Juan, the annotation for the new release of the Octane 2020.1.4 says the following:
Sorry, I don't any Windows 7 system here, but a new plugin build including the new 2020.1.4 will be available in the upcoming days, so if you still have a Windows 7 system, you should be able to check it out yourself ;)
promity
Ok, thank's.
Lightwave 3d
