Daylight models ground color?
Posted: Wed Jul 01, 2020 11:01 am
by kirk
Why I see nothing setting any color there? I need to have something resembling ground for proper color bleeding and light bouncing while I use ground plane as a shadow catcher
Re: Daylight models ground color?
Posted: Wed Jul 01, 2020 4:05 pm
by frankmci
The default Ground Start Angle is 90, or basically, directly down and therefore non-existent. Set it to 0 and it will go right to the horizon.
Posted: Fri Jul 03, 2020 8:42 pm
by kirk
frankmci wrote:The default Ground Start Angle is 90, or basically, directly down and therefore non-existent. Set it to 0 and it will go right to the horizon.
Thank you frankmci . It seams not working with Preetham Daylight Model I like. But works with others
Posted: Tue Jul 07, 2020 9:45 pm
by frankmci
kirk wrote:frankmci wrote:The default Ground Start Angle is 90, or basically, directly down and therefore non-existent. Set it to 0 and it will go right to the horizon.
You might check to see if that daylight model even supports ground color. If it does, but isn't showing up in Octane, I'd report it as a core bug.
