Archive/ export ORBX and abc
Posted: Thu Jun 04, 2020 4:21 pm
by Ebo
Hi. I am getting empty files when exporting a frame range through the Archive tab. Thank you
Re: Archive/ export ORBX and abc
Posted: Fri Jun 05, 2020 8:25 am
by juanjgon
Do you have a scene with a valid camera and render target? If you want to share your scene, I could take a look at it here.
Posted: Fri Jun 05, 2020 9:03 am
by Ebo
Sorry, I thought I did attach the file to the post.
Posted: Fri Jun 05, 2020 10:03 am
by juanjgon
Hmm, it is true. The plugin doesn't finalize the .orbx file while exporting animations. I'll investigate this issue ASAP, it can be a bug in the latest builds. The orbx export from single frames seems to work fine.
Posted: Tue Jun 09, 2020 8:43 am
by juanjgon
It is funny. This problem only happens if you export 24 frames. If you export any other number of frames (for example 23 or 25) all works fine. While investigating why this happens, the workaround is to try to avoid exporting proxy files with this number of frames.
Posted: Tue Jun 09, 2020 11:09 pm
by Ebo
:) lol, ok. I can live with that restriction :). Thank you
