Water/Sweat/Oil Skin addons
Posted: Wed May 27, 2020 1:03 am
by Nephanor
Anyone had any luck, or know of any tutorials to make sweat droplets on skin easy, or giving a skin an oiled look? I have seen the recent addon for Daz, but was hoping to see something like it for Octane, maybe even one that will work for both Poser and Daz.
Re: Water/Sweat/Oil Skin addons
Posted: Thu May 28, 2020 9:56 pm
by Nephanor
Okay, I am going to give my thoughts on how this could be accomplished in an abstract way, but not the actual detailed ways, as I still can't work those out in my head.
Wet
This one is actually simple, provided you are just talking simple non-displacement glossiness, all you do is add a "gloss map" for the glossy part of the skin. So this one is simple. But....
Oil/Sweat
Basically you are creating a 'layer' over the skin. The layer adds a small displacement of either droplets or a thin film, which then gets the specular water/oil texture added to it. Problem is, how do you add that layer over top of the existing skin? The first thought I had on this is basically make a duplicate of the figure, and 'blank' out all textures but the skin, which you then apply the film texture to. But this feels like it will be a pain for the engine. Not only that, I am hoping to see a simple, "just add it in" possibility that I may not have though of.
Thoughts?
Posted: Fri May 29, 2020 11:28 am
by wimvdb
If you have Octane 2020, you can add a layer directly.
In Octane 4 you can create a mix material - use your normal skin node in material 1 and your specular layer for oil/water in material 2. Use the value operator to manage the strength.
Posted: Fri May 29, 2020 8:29 pm
by Nephanor
wimvdb wrote:If you have Octane 2020, you can add a layer directly.
Don't have Octane 2020. I paid for 3/ 4 and am not a fan of the whole subscription model, would rather just have the software without having to keep paying for it. But if it has layers, I might consider it, but I would prefer a straight purchase option. If I had known a few years ago when I bought it that they were going to go subscription, I might have not gotten it and gone a different path. After investing this much money, I feel cheated.
The Mix material doesn't work, I tried. At .5, the skin is half transparent, and if you make the skin less transparent you lose the specular effect entirely.
Posted: Sun May 31, 2020 8:47 am
by wimvdb
You are right.\
I checked on an old wet skin material and I used not a specular, but a glossy material as second material.
With this result
Needs finetuning, but is a start.
Now I use a specular layer in octane 2020
Posted: Mon Mar 01, 2021 4:27 am
by Nephanor
Yeah, I know, thread necromancy, but now that I have the new version is there any good tutorials for using the layers?
