Fading an object without seeing geometry behind it ?
Posted: Sun May 24, 2020 11:08 am
by lalalem
Is it possible to fade out an object in 2D like in After Effects ? When I try using the opacity float in the material, or the c4d octane objet tag (visibility tab) I can see unwanted parts of the geometry behind the object in different shades.
Is there a way around this ?
Re: Fading an object without seeing geometry behind it ?
Posted: Mon May 25, 2020 1:30 am
by Jengo_1
What you mean different parts of the geometry?
I've done it using the opacity in the shader - plug in a float node into the opacity and keyframe from 1 to 0. Is that how you did it?
